CUKTECH Launches Two New Chargers, Portable Fan; Priced From RM149
One of the chargers features Bluetooth connectivity so users can monitor charging performance from their phones.
by Kiran Ganesan
August 21, 2026
CUKTECH Fan, Charger
CUKTECH 10 Ultra Charger (Image: CUKTECH)
281
CUKTECH has officially announced three new products in Malaysia: two chargers and a portable fan. The two chargers are the CUKTECH 6 Ultra Charger and the CUKTECH 10 Ultra Charger, while the fan is called the CUKTECH CP Turbo Fan Plus.
6 Ultra Charger (Image: CUKTECH)
In order of appearance, the 6 Ultra Charger delivers up to 100W of power through two USB-C ports and a singular USB-A port. Like most chargers today, it can provide power to multiple devices simultaneously, but the company claims that it can do this effortlessly because it is built with advanced GaN (gallium nitride).
The brand also notes that the device can automatically adjust its output according to the needs of connected devices. Users can view which devices are getting how much power through the 0.96-inch smart display. Lastly, it comes with an OPC 2.0 Smart Charging technology which allows the charger to work with various device ecosystems, or so the company claims.
Next is the 10 Ultra Charger, which is essentially a robust variant of the previous charger. This charger has a total output of up to 120W and comes with three USB-C ports and one USB-A port, which can be used to charge phones, tablets, smartphones, and more. For laptops specifically, it supports up to 100W charging alongside a wider multi-device setup.
Much like its sibling, this charger can automatically distribute its output to different devices simultaneously, and users can see how much power is allocated to them with the integrated screen. The only difference is that the 10 Ultra Charger comes with a bigger 1.57-inch TFT smart display. According to the press release, the screen keeps track of the device power output, voltage, and current and operating temperatures.
It’s also worth noting that it also features Bluetooth connectivity and integration with the Mi Home apps, which allows users to view its charging performance from their smartphones. While consumers can travel with this charger, it weighs in at 239g. As a result, the company is advertising this charger as the ideal power solution for fixed workstations.
CP Turbo Fan Plus (Image: CUKTECH)
Last is the CUKTECH CP Turbo Fan Plus. In terms of performance, the brand says that its three-phase brushless motor can spin at up to 30,000 revolutions per minute (rpm) and produce wind speeds of up to 11 metres per second. The portable fan comes with three standard speed settings, along with a BOOST mode for an instant burst of high-speed airflow.
Beyond that, the fan also features what the company calls a modular magnetic design, allowing the fan and battery modules to be attached or detached as needed. The 10,000mAh battery module can power the fan, function as a portable power bank, or do both simultaneously.
CUKTECH CP Turbo Fan Plus (Image: CUKTECH)
According to the press release, the battery can provide up to 37 hours of operating time for the fan, depending on the selected speed. Beyond that, its USB-C port supports up to 27W input and 33W output. Meanwhile, its Power-Pin Magnetic interface supports up to 25W output.
Pricing And Availability
Once again, all three products are now available in Malaysia. As for pricing, the company is charging RM149 for the 6 Ultra Charger, RM189 for the 10 Ultra Charger, and RM199 for the CP Turbo Fan Plus.
However, the company is offering special launch prices for all three products. They are priced at RM145, RM183 and RM193, respectively. These promotional prices will be available for one month from the official launch date. Regardless of lacklustre discounts, those interested can purchase the products via the brand’s official Shopee page.
(Source: CUKTECH press release)
Filed Under cuktech
Updated 5:53 pm, Fri, 21 August 26
SendShareShareShare112Tweet70
