Brought to you by Xiaomi
REDMI Note 15 Pro 5G: Titan Durability That’s Made To Last
This smartphone can survive anything life throws at it, and then some!
by Newsdesk
January 15, 2026
REDMI Note 15 Pro 5G Sponsored Images
874
The REDMI Note 15 Pro 5G has just landed in Malaysia, and with its arrival comes the new robust standard for smartphones. It may look like your everyday smartphone, but in actuality it is a hardy partner designed to withstand everyday challenges.
Featuring a heavily reinforced body with quadruple waterproofing certifications, this smartphone is designed for those who aren’t afraid of living an adventurous life. Add on top of a bevy of photographic capabilities and a robust battery, this device can be by your side for many years to come.
A True Titan Of Durability
Unlike most smartphones in its price range, the REDMI Note 15 Pro 5G device features several design improvements for maximum resistance durability – inside and out. It has a high-strength fibreglass back panel with 10x impact resistance, allowing it to shrug off accidental knocks and even brutal drops.
The screen also receives some potent upgrades as well. Xiaomi has outfitted the phone with Corning Gorilla Glass Victus 2, ensuring maximum protection against drops and scratches. It is so rugged that it can easily survive a 2.5 metre front drop test without any major issues.
As mentioned earlier, the REDMI Note 15 Pro 5G also features additional reinforcements for its internal components. Dubbed the REDMI Titan Structure, this flagship-level reinforcement integrates a high-strength motherboard and a reinforced mid-frame to deliver multi-layered protection for lasting durability and reliability.
To demonstrate that the REDMI Note 15 Pro 5G is an exceptionally robust smartphone, it has earned the SGS Premium Performance Certification, receiving a 5-Star rating for drop, crush, and bend resistance.
Of course, that is not to mention the handset’s flagship-level water resistance. Unlike its competition, the REDMI Note 15 Pro 5G features quadruple-certified waterproofing with its IP66, IP68, IP69, and IP69K ratings. It is also certified with the TÜV Smartphone Water-Resistant Endurance, guaranteeing that it can weather any storm.
Not only that, this device also has Wet Touch 2.0. This ingenious feature detects water, oil, foam, sweat, and more, keeping your touch interactions smooth, accurate, and responsive in everyday scenarios.
Durability is one thing, but what about longevity? Many smartphone buyers often hesitate from buying a new mid-range device, thinking that it will only receive support for a few short years. Luckily, the REDMI Note 15 Pro 5G will receive four years of OS and six years’ worth of security updates, which is almost unheard of from your everyday mid-rangers.
And that’s not to mention the 1+1 standard warranty on top of all that, making this the rare handset that is truly made to last. You’ll also get a 2-year accidental warranty on screen, liquid, and back cover repair in case something does break, but for one time only.
Related Article Redmi A7 Pro Launches In India; Coming To Malaysia Soon
6,580mAh Battery: Keeping Up With Your Daily Adventure
Needing to charge your phone can be a hassle at times, especially if you need to be on the move. Thankfully, the REDMI Note 15 Pro 5G has made that problem a thing of the past! Its massive 6,580mAh battery can keep your phone running for more than two days of typical use.
And if you are in need of a charge, the 45W HyperCharge can easily get you back to 100% in just a few hours! It can also keep your other devices topped up as well with its 22.5W wired reverse charging.
While this might sound demanding on the device’s power system, it’s actually not. The Silicon-Carbon cell, managed by the Xiaomi Surge battery management system, can retain up to 80% of its capacity after 1,600 charge cycles, which is roughly equivalent to up to six years of regular use.
Xiaomi is also quite confident with the REDMI Note 15 Pro 5G’s battery, so the phone also has a four-year battery warranty. In the event the battery health goes below 80% within four years, you’ll receive a replacement battery for free.
Flagship Snapper In A Mid-range Body
Just because this device is a mid-ranger, that does not mean it doesn’t have a potent camera array to go along with it – far from it. This smartphone can satisfy all your photography needs, especially thanks to its all-new 4th generation 200MP main camera with OIS.
This main shooter is also equipped with an f/1.7 aperture and a 1/1.4-inch sensor size, ensuring that every photo you snap is bright and full of detail. It is also capable of capturing at five different focal lengths as well as up to 4x optical-level telephoto zoom, making sure you capture every minute feature of your subject.
In case you need to fit a little bit more for, say, a group photo, then its 8MP ultrawide camera makes sure no little subject is left behind. You’re also guaranteed to snap crystal-clear selfies every time thanks to its 20MP front-facing camera.
Related Article Xiaomi Unveils New Wearables, Including Watch S5, Smart Band 10 Pro, And Buds 6
A Pocketable Multitool At Budget Friendly Pricings
With all these features, would you believe that is only the tip of the iceberg? That’s right! From its Mediatek Dimensity 7400-Ultra chipset to its Xiaomi Offline Communication function and various AI capabilities, the REDMI Note 15 Pro 5G offers a whole slew of features waiting to be explored. The only thing missing is you!
The REDMI Note 15 Pro 5G is now available, priced at RM1,399 for the 8GB + 256GB model and RM1,599 for the 8GB + 512GB variant. However, in celebration of the series launch, Xiaomi is offering a special pre-promotion! If you pre-order from 16 to 21 January 2026, you’ll receive a REDMI Pad SE 8.7-inch tablet with a cover (worth RM748) for free! And, for a limited time, you’ll get a free upgrade to the 512GB version.
Enjoy incredible durability and versatility like never before with the REDMI Note 15 Pro 5G! For more information, visit any Xiaomi store or mi.com and enjoy the true titan of durability!
This article is brought to you by Xiaomi.
Filed Under redmiREDMI Note 15 Pro 5Gxiaomi
Updated 8:45 pm, Thu, 22 January 26
SendShareShareShare350Tweet219
    Audio
    Panasonic Is Closing Down Its Malaysian AVC Factory And Moving Technics Hi-Fi Production
    Transportation
    Touch ‘n Go Launches Enhanced RFID Lane For Seamless Tolling
    X Money Rolls Out To Premium X Subscribers In The US
    JPN Dispels Viral MyKad Address Enforcement Campaign Claims
    Xiaomi 18 Pro Series May Launch Globally With Secondary Display, New AI Button
