Home Mobile Phones
Redmagic 11 Pro Arriving In Malaysia On 10 November 2025; Starts From RM3,399
Currently in the running to be the first Snapdragon 8 Elite Gen 5 smartphones to debut locally.
by Heirul Kamel
November 6, 2025
Redmagic 11 Pro series
Image: Redmagic
40
Redmagic has officially launched its latest flagship gaming smartphone, the Redmagic 11 Pro, for the local market. It is powered by Qualcomm’s Snapdragon 8 Elite Gen 5 processor, supported by the brand’s dedicated RedCore R4 gaming chip and more. Slated for release on 10 November 2025, it is also looking to be the first Snapdragon 8 Elite Gen 5 equipped smartphone to arrive in Malaysia.
As mentioned previously in our last article, the local version of the Redmagic 11 Pro isn’t identical to the Chinese release. Instead, it’s effectively a rebranded Pro+, with a small change in battery specifications.
redmagic 11 pro launch malaysia
Image: Redmagic
On the front, the 11 Pro features a 6.85-inch BOE X10 AMOLED display with a resolution of 1,216 x 2,688 pixels. The panel supports a 144Hz refresh rate for smooth gameplay and a peak brightness of 1,800 nits. Other key hardware features include an under-display fingerprint scanner, built-in shoulder triggers, RGB lighting on the rear panel, and an IPX8 water resistance rating. Buyers can choose between a matte black Cryo finish or the transparent Nightfreeze and Subzero editions.
Internally, the Redmagic 11 Pro pairs the aforementioned Snapdragon flagship chip with the RedCore R4 for improved haptic feedback, audio, and network response. The phone offers up to 24GB of RAM and up to 1TB of internal storage. Powering the device is a 7,500mAh battery, which supports 80W wired charging and 80W wireless charging.
Also onboard is the brand’s AquaCore hybrid cooling system, which features a visible liquid channel on the transparent models. The setup combines a 13,116mm² vapour chamber, a layer of liquid metal, and an internal fan capable of spinning up to 24,000 RPM to maintain optimal performance under load.
Redmagic 11 Pro
Image: Redmagic
Redmagic 11 Pro+
Image: Redmagic
Redmagic 11 Pro+
Image: Redmagic
For photography, the Redmagic 11 Pro comes with a dual 50MP camera system consisting of a main and ultrawide sensor. On the front, a 16MP sensor is available via an under-display selfie camera.
Image: Redmagic
The Redmagic 11 Pro retails locally at RM3,399 for the 12GB + 256GB model and RM4,999 for the top-end 24GB + 1TB variant, though note that the latter is only available in the Nightfreeze and Subzero finishes. You can pre-order the phone now through the brand’s website, flagship stores, and its official Shopee, Lazada, and TikTok online outlets. As mentioned earlier, the phone is slated to arrive on 10 November 2025.
(Source: Redmagic Malaysia press release)
RELATED:  Redmagic 11 Air Debuts In China With Snapdragon 8 Elite, 7,000mAh Battery
Filed Under redmagicredmagic 11 pro
Updated 7:33 pm, Thu, 6 November 25
https://lowy.at/yan2t
SendShareShareShare16Tweet10
    Audio
    Gaming
