Home News Rumours & Leaks
AMD Ryzen AI “Sound Wave” APU Appears In Shipping Manifests
It's finally make some waves.
by John Law
October 15, 2025
AMD-3rd-Gen-Ryzen-AI-1
AMD’s Ryzen AI APU, Sound Wave, isn’t a name you’d be familiar with but it has appeared in the past. Recent rumours have suggested that the APU could be the chipmaker’s ARM-based APU, marking the return of a non-x86 processor after more than a decade.
Recently, a shipping manifest listing the alleged Sound Wave APU has surfaced, along with some specifications on its packaging. According to the source, the APU uses a BGA-1074 package, measuring 32 x 27mm, as well as a FF5 interface with a 0.8mm pitch.. For context, that’s about the size of a small chip found in mobile and handheld devices, while the interface is newer than the FF3 connector used in devices such as the Steam Deck.
Soundwave – SWV
BGA1074
32mm x 27mm pic.twitter.com/lcArm96nCy
— Gray (@Olrak29_) October 12, 2025
Other reports suggest that Sound is to be a low-power component, running below the 10W range and therefore, possibly positioning it as a low-power component for Windows on ARM systems. Specs-wise, it’s been speculated that the component features two P-Cores, and four E-Cores, similar to Intel’s current processor lineup, while also integrating four RDNA 3.5 CUs. That last bit is still unconfirmed, by the way.
AMD itself hasn’t officially made any announcements about Sound Wave, but if this turns out to be true, then the red chipmaker would be squaring off with the likes of Qualcomm in this space. As it stands, it has to go up against the likes of the Snapdragon X2 Elite SoC, which is set to feature up to 18 combine cores.
RELATED:  AMD Ryzen Max 500 "Medusa Halo" APUs Could Support LPDDR6 Memory
(Source: X, ITHome)
Filed Under AMDsound wave
Updated 12:24 pm, Wed, 15 October 25
https://lowy.at/mddae
    BYD Reportedly Reconsidering Tanjong Malim CKD Plans
    Mobile
