It goes without saying that people are extremely particular when it comes to their phones, and why should they be? These devices have been the most optimal choice when it comes to on-the-go gaming, high-end photography, and even as a fashion accessory all on their own. And for the longest time, people couldn’t have all three until now.
Enter the OPPO Reno14 Series — the latest handheld that delivers stunning photographic and gaming capabilities wrapped in a dazzling body. Tied together with the most potent of AI systems, this smartphone series has been built to capture the beauty of the world around you with every tap.
AI Photography: Shine Brighter Than Fireworks
When it comes to modern smartphones, the camera is often the star of the show — and the OPPO Reno14 Pro certainly lives up to the hype. It boasts a 50MP primary camera, a 50MP ultra-wide camera, a 50MP 3.5x telephoto camera, and a 50MP front-facing camera, making it the most powerful camera setup in the Reno lineup. With this, capturing the perfect shot becomes second nature.
Both the main and wide-angle cameras now feature dual flash units that deliver up to 120 lux brightness at one metre — twice as powerful as before — ideal for stunning portrait shots. Meanwhile, the 3.5x telephoto camera gets its own dedicated focus flash, shining up to 70 lux at two metres. That’s ten times brighter than previous models and the brightest telephoto flash in the industry today.
But that’s just the beginning. Each rear camera is an ultra-clear low-light camera supported by a 3-flash design and advanced AI processing. Depending on your need, you can switch between Flash Mode for sharp, dimensional portraits or Fill Light Mode for soft, natural lighting — both designed to make every photo look like it was taken on professional gear.
The Reno14 Pro goes even further with AI Livephoto 2.0. Thanks to a hardware-level Dual Exposure Fusion system, it merges long and short exposures in real time, turning three-second videos into high-resolution 4K live photos. You can even extract any frame as a photo, and the AI will enhance it while preserving ProXDR quality.
This AI power also extends to full videos. All three rear cameras support AI-enhanced 4K HDR video recording, allowing seamless focal length transitions with crystal-clear quality throughout. And for vloggers, the AI Vlog Voice Enhancer intelligently minimises background noise during recording. The front camera includes its own Selfie Vlog Voice Enhancement, keeping your voice front and centre in every take.
High-Performance Gaming: EZGameEZShare
Anyone familiar with AI knows it demands serious processing power — and the OPPO Reno14 Pro delivers just that. It’s powered by the MediaTek Dimensity 8450, the world’s first chipset to feature Cortex-A725 All Big Core architecture across all eight CPU cores. This translates to up to 41% better multi-core performance and 44% less power consumption. Complementing this is the NPU 880, a dedicated AI processor that boosts performance by 54% while improving energy efficiency by up to 18% compared to its predecessor.
When it comes to gaming, overheating can ruin the experience. That’s where the AI Nano Dual-Drive Cooling System comes in. With a nano-fluid ultra-thin vapour chamber, it efficiently dissipates heat from the SoC, keeping your device cool and comfortable even during long sessions.
For gamers and content creators alike, AI Game Highlights makes it easy to capture your best moments. Simply record your gameplay and let the AI automatically select the highlights using in-game visuals like kill graphics. Want something snappier? Game Capture lets you create short-form 15- or 30-second videos — perfect for epic pulls, MOBA takedowns or new skin reveals. You can even take 3-second Live Photo screenshots to make every capture more dynamic.
To support all this power, the Reno14 Pro packs a massive 6,200mAh battery, ideal for hours of uninterrupted play. And when it’s time to recharge, the 80W SUPERVOOC fast charging takes you from 0% to 100% in just 47 minutes. It also supports 50W AIRVOOC wireless fast charging with the optional OPPO charger.
Stunning Design: Endless Vibes
Though it boasts an incredible camera array and processing power, that does not mean this device is a slouch when it comes to design. The handheld showcases a dazzling, iridescent mermaid design, filled with finer, multi-coloured light and shadow effects, which allows it to be a fashion statement all on its own. This is made possible thanks to the fact that the Reno14 Pro is the industry’s first velvet glass — a technical marvel that features dazzling textures that you can both see and touch.
And if by any chance the sheer size of the camera array bothers you, OPPO has found an innovative way to make it tastefully brilliant. Building on top of its predecessor’s success, the Reno14 Series innovates with a centralised Gradient Aura Design which reduces the camera’s prominence among the design and creates a perfect balance between it and the rest of the phone body.
Every Moment, Even Underwater
Doubling down on its mermaid-inspired design, the Reno14 Series features an IP69 water and dust resistance, allowing it to shrug off sudden plunges and dips into pools and even open waters. To maximise its resistance, you can use the Reno14 as your dedicated underwater camera thanks to its underwater photography mode.
Naturally, handling your phone underwater is quite tricky, which is why the underwater photography mode features a variety of operating methods to help ease your use while you’re swimming with the fishes.
Operating Methods:
- Volume Up key: Take a photo with a 4:3 aspect ratio; supports Live Shot during video recording.
- Volume Down key: Record a video (1× zoom by default) at a 16:9 aspect ratio and 1,080P@30fps
- Lock Screen key: Turn the screen off
- Long Press Lock key: Exit Underwater Photography mode
ColorOS 15: Made With The Best Of Both Worlds
Tying everything together is, without a doubt, the ColorOS 15. Powered by two independently developed engines, the Trinity Engine and the Luminous Rendering Engine, this potent operating system is designed to deliver exceptionally smooth performance around the clock. It merges the best of both worlds, taking the smart caching and CPU optimisation from the Trinity Engine and Android rendering framework of the Luminous Rendering Engine to create a game-changing system. With five major updates to the ColorOS, the Reno14 Series is here to stay for years to come!
The ColorOS 15 brings a wide range of intelligent features to the Reno14 Series. One such feature is the AI Toolbox, a unique system that adapts to your habits, offering tools that are customised for your daily needs. Features range from AI Writer, AI Reply, AI Summary, and even AI Assistant for Notes!
Grab the latestOPPO Reno14 Series now until 10 August to enjoy exclusive rewards worth up to RM2,196!
- Reno14 Pro (Opal White & Titanium Grey)
- 12GB + 512GB RM2,999
- Reno14 5G
- 12GB + 512GB Opal White RM2,599
- 12GB + 256GB Luminous Green RM2,199
- 12GB+512GB Opal Blue / Luminous Green RM1,799
- 12GB+256GB Opal Blue / Luminous Green / Glossy Pink RM1,599
- (online exclusive only) 8GB + 256GB Opal Blue / Luminous Green RM1,399
Be sure to snag these phones during this promo period, fast! If you do, you’re entitled to receive an RM100 rebate! For more information, please visit OPPO’s official website.
This article is brought to you by OPPO.
