Home Hardware Memory
G.Skill Launches Large Capacity 256GB DDR5-6000 UDIMM Memory
Built specifically for use with AMD systems.
by John Law
April 22, 2025
G.Skill-DDR5-6000-256GB-ultra-high-memory-kit-1
(Image: G.Skill.)
G.Skill officially announced its latest ultra-high capacity kit of 256GB DDR5 UDIMM RAM. The kit comprises four 64GB memory sticks, running at 6000MT/s, along with CL32 timings.
“Built with high-performance SK hynix DDR5 ICs, this overclocked memory speed and timing pushes the boundaries of memory overclocking by fully loading four modules of high-capacity DDR5 64GB U-DIMM modules on a single system; marking a new milestone for high-performance computing, content creation, AI applications, and advanced workstation workloads.”
(Image: G.Skill.)
(Image: G.Skill.)
The new G.Skill ultra-high memory kit was designed primarily to work with AMD systems. To that end, the DDR5-6000 memory kit was verified vai the use of an AMD Ryzen 7 9800X3D and ASUS ROG Crosshair X870E Hero, as well as a Ryzen 9 9900X paired with an MSI MPG X870E Carbon Wi-Fi motherboard.
At the time of writing, G.Skill did not specify local pricing or availability. Needless to say, such a memory kit won’t come cheap and you can expect to pay a pretty penny for it.
(Source: G.Skill PR)
RELATED:  Scammers Are Now Reportedly Passing Off DDR2 Memory As DDR5 RAM Kits
Filed Under DDR5G.Skill
Updated 3:39 pm, Tue, 22 April 25
https://lowy.at/9tjtl
    Audio
    Gaming
