Home Fintech
CIMB Announces Full Implementation of SecureTAC On 18 April
No more SMS OTP for all online debit or credit card transactions.
CIMB OCTO SMS
20
CIMB Bank has published a notice on its site announcing that it will be replacing the use of SMS OTP with SecureTAC via its OCTO app for just about all types of transactions. Or more specifically, SecureTAC will be used “for all CIMB Debit and Credit Cards Cards-Not Present (CNP) 3D Secure (3DS) transactions.
Or to put it simply, all online transactions using the bank’s credit or debit cards that require the authentication of the card holder. This will go into effect at the end of the week, or more specifically on 18 April.
CIMB Google Wallet Octo
Image: The Edge Malaysia
On that note, the bank has previously put up a separate notice that it is discontinuing the CIMB Clicks app, so things will have to be done exclusively via the OCTO app. Breaking it down, the notice points out that starting 12 April, FPX transactions can no longer be approved though the Clicks app. Then on 19 April, a day after SecureTAC completely replaces SMS OTP, the Clicks app as a whole will be discontinued, with account access no longer being available.
In short, if you are a CIMB Bank customer, you’ll have to migrate completely from the Clicks app to the OCTO app within the week anyway. You can read the new notice for yourself by hitting the links below. The CIMB Octo app is available via the Apple App Store, Google Play, as well as Huawei AppGallery, though your device needs to have either iOS 12.5, Android 9 or newer.
(Source: CIMB [PDF])
RELATED:  CIMB Islamic, PTPTN Put RM500,000 Up As Incentive For Prompt Loan Repayments
Filed Under AppBankingCIMBClicksfintechmobileOCTOotpSecureTAC
Updated 2:15 pm, Wed, 16 April 25
https://lowy.at/hogfp
SendShareShareShare8Tweet5
    BYD Reportedly Reconsidering Tanjong Malim CKD Plans
    Mobile
