Home Hardware Display
Gigabyte MO27Q28G Gaming Monitor Now Available At RM2,999
Available at all authorised resellers.
by John Law
September 30, 2025
29
Gigabyte officially announced that its MO27Q28G gaming monitor is now available in Malaysia. The monitor is the latest of several other monitors in the market to utilise a Tandem OLED panel.
Running through the other specs, the MO27Q28G is a 27-inch WOLED gaming monitor with a native resolution of QHD (2,560 x 1,440). Its design allows for a 4-sided borderless aesthetic, giving it a 99% screen-to-body ratio. Again, it is a Tandem OLED, with its panel being a fourth generation LG Display WOLED panel.
Moving on, the MO27Q28G has a maximum refresh rate of 280Hz with a 0.03ms GTG response time. It is also a VESA DisplayHDR True Black 500 certified monitor, with a peak brightness of 1,500 nits, 99.5% DCI-P3 colour gamut, and black levels of up to 500 lux.
The MO27Q28G also comes with brand-specific exclusive features, including Tactical Switch 2.0, enabling gamers to switch between resolutions and aspect ratios, all with a single click of the switch. Ports-wise, it comes with two HDMI 2.1 ports, one DisplayPort 1.4 port, a USB-C upstream port, two USB3.2 Downstream, one USB 3.2 Upstream, and a 3.5mm earphone jack. Finally, the total weight of the monitor stands at 8.75kg, with the monitor weighing around 4kg.
The MO27Q28G retails for RM2,999.
RELATED:  Gigabyte Won't Build An AORUS Handheld Just For The Sake Of Making One
Filed Under AorusgigabyteMO27Q28G
Updated 5:15 pm, Tue, 30 September 25
https://lowy.at/7l2gs
SendShareShareShare12Tweet7
    Audio
    Gaming
