  • Wanista
Home Mobile Accessories
CUKTECH Launches Power Bank, Mini Fan; Priced From RM47
There's also a "magnetic OLED fast charging cable" being part of the launch.
CUKTECH 10 Mini Power Bank
Image: CUKTECH
14
Power bank brand CUKTECH has announced three new products to its lineup starting today. But they are not all power banks; in fact, two of them aren’t. The one that is, is called the CUKTECH 10 Mini Power Bank, with the other two being the CUKTECH 6 Magnetic OLED Fast Charging Cable and the CUKTECH CP Outdo or Mini Fan.
Going in order, the power bank has a 10,000 mAh capacity, while still being able to fit in your hand. The company rates its output at 55W, supporting “major fast-charging protocols including PD 3.0, PPS, UFCS and Xiaomi HyperCharge”. There’s also an LED display to show its remaining charge, as well as if it has devices plugged into it. On that note, it features two USB-C ports and a USB-A port.
Image: CUKTECH
Moving on the the magnetic OLED fast charging cable. The key takeaways here are that it’s a 1.5m braided cable that supports 240W charging. The brand does specify PD 3.0 and Xiaomi 6A protocols for what it’s worth. For the OLED part of the equation, this is a screen that shows real-time voltage, current and wattage, letting you know it is working as intended when in use. As for the magnetic bit, this helps the cable stay coiled when not in use instead.
Finally, the outdoor mini fan. In lieu of a battery, you get a USB-A plug on the tail end of the thing. This means that you’ll need a separate power bank to use it, but the company claims a 22.5-hour usage when paired with a 10,000 mAh power bank. It has three adjustable “wind modes”, and the company claims that it is “whisper quiet”.
CUKTECH CP Outdoor Mini Fan
Image: CUKTECH
CUKTECH is charging RM106 for the power bank, RM49 for the cable, and RM47 for the fan, with a caveat. Said fan is available in two colours, but if you want the black colour option, you’ll have to wait until sometime in September. The rest are now available via the brand’s official stores in Lazada and Shopee.
Filed Under cuktech
Updated 1:33 pm, Wed, 6 August 25
https://lowy.at/9pvpr
Share6Tweet4SendShare
    E-commerce
    Android Phones
    E-commerce
  • Wanista
