Home Mobile Phones
Leaked Samsung Galaxy S25 FE Renders Reveal Slim Design
The phone looks pretty familiar otherwise.
by Nurul Kamil
June 21, 2025
Samsung Galaxy S25 FE leak
Image: OnLeaks via SammyGuru
24
While much of the attention is focused on the upcoming Samsung foldables, which are set to be unveiled next month at the company’s Unpacked event, there is one more high-end phone currently in the works. The Samsung Galaxy S25 FE is expected to be released sometime later this year, and it has recently made an appearance in a set of CAD-based renders.
This first look at the phone is courtesy of a report by SammyGuru, and at a first glance it seems like the S25 FE will closely resemble its predecessor, with familiar flat frames, punch-hole display, and triple camera setup. Clearly, Samsung is not planning on any drastic makeovers for this device.
That said, there are some minor changes compared to the Galaxy S24 FE, mainly in terms of dimensions. According to the leak, the S25 FE will measure 161.4 x 76.6 x 7.4mm, which means it will be a touch shorter and thinner than the S24 FE. For reference, the measurements of the S24 FE are 162 x 77.3 x 8mm. The S25 FE will still sport a 6.7-inch display, though, and that will probably be achieved by slimming down the bezels.
At the time of writing, Samsung has yet to offer any details about the Galaxy S25 FE, so all we have for now are rumours. One of the claims so far is that the phone will be powered by either the Exynos 2400 or Dimensity 9400 SoC, paired with 12GB of RAM. It will allegedly have 256GB and 512GB storage options. It’s also likely that it will also run on One UI 8 right out the box.
RELATED:  Samsung Galaxy Z TriFold Reportedly Getting Axed Just Three Months After Launch
As for other rumours, it has been previously speculated that the S25 FE will feature a 50MP main sensor, an 8MP telephoto lens, and a 12MP ultra-wide-angle camera. If that also sounds familiar, that’s because it’s the same setup as the current FE. However, the selfie camera might get upgraded to a 12MP unit.
(Source: SammyGuru via GSMArena)
Filed Under Galaxy S25 FELeakRumourSamsungSmartphone
Updated 11:01 pm, Fri, 20 June 25
https://lowy.at/0xw6i
SendShareShareShare10Tweet6
    Hybrid Vehicles
    Banking
    Gaming
