Home Computing
Acer Launches TravelMate P6 14 AI Laptop, Vero CB2 Monitor In Malaysia
The latter comes in 24- and 27-inch variants.
Acer TravelMate P6 14 AI
17
Acer has its long-running TravelMate series of laptops, and one member of the line got a refresh today, with the launch of the TravelMate P6 AI. Alongside the laptop, the company also launched the Vero CB2 monitor, which comes in two sizes.
But let’s start with the Acer TravelMate P6 14 AI. As the name suggests, this is a 14-inch laptop with a 16:10 aspect ratio screen. You can have a choice of WQXGA (2,880 x 1,800) resolution, or WUXGA (1,920 x 1,200) with touch screen as options. It also gets a carbon fibre lid which, when added to the magnesium-aluminium alloy, allows it to weigh under 1kg.
Acer TravelMate P6 14 AI left ports
Acer TravelMate P6 14 AI right ports
Inside, it packs a Intel Core Ultra 200V processor, going up to Core Ultra 7 268V, with memory options going up to 32GB LPDDR5X, and storage options going up to 1TB. It also comes with a 65Wh battery. Connectivity options include WiFi 7 and Bluetooth 5.4, with Bluetooth LE also being specifically mentioned. Wrapping it all up is the MIL-STD 810H certification. The Acer TravelMate P6 14 AI comes in three configurations, with a starting price of RM6,799.
Acer Vero CB2 front
Acer Vero CB2 back
Accompanying the laptop is the Acer Vero CB2, as mentioned this comes in two sizes, 24- and 27-inches, which are designated CB242Y G and CB272 G. These are simpler in comparison to the laptop, and they are nearly identical aside from their size. Both come with Full HD IPS panels with a 120Hz refrersh rate, and they take VGA, HDMI and DisplayPort input. They are priced at RM469 and RM599, respectively.
RELATED:  Acer Announces Predator X27U F5 Gaming Monitor With 500Hz Refresh Rate
Filed Under acerLaptopMonitorTravelMate P6 14 AIVero CB2
Updated 1:22 pm, Tue, 15 April 25
https://lowy.at/ftqd3
SendShareShareShare7Tweet4
    Audio
    Gaming
