Home Mobile
Motorola One Appears On TENAA; Features A 720p Display And Snapdragon 625 SoC
by Sharil
August 21, 2018
The Motorola One Power is set to be the company’s next Android One device, and we have seen early renders thanks to leaks along the way. Now a new lower-specced model called Motorola One has appeared on TENAA, baring all of its specs to the world.
Specs-wise, the Motorola One comes with 5.88-inch HD display and a Qualcomm Snapdragon 625 SoC. It will also be available in three memory configurations: 4GB, 6GB and 8GB. Along with three internal storage configurations as well: 32GB, 64GB and 128GB.
It also appears that the Motorola One will come equipped with four cameras sensors, with the the main camera array will most likely sport a dual camera setup. The TENAA listing did not specify the secondary sensor’s resolution, but we do know that the main camera is a 13MP sensor and that the selfie is an 8MP sensor. Speculations also suggests that the second sensor is specifically for depth-data, which can be used for faux-bokeh photography.
The listing shows that the Motorola One will have a 3000mAh battery. It will also ship with Android One 8.1 installed on it, with an Android 9 Pie update to be made available for it soon after.
(Source: TENAA via GSMArena)
Filed Under MotorolaMotorola One
Updated 4:52 pm, Tue, 21 August 18
http://lowy.at/hzLYq
SendShareShareShare1Tweet1
    Gaming
    Audio
    Hybrid Vehicles
