Cooler Master Launches The Silencio FP 120 PWM Fan
by Terry Bass
April 23, 2015
The New Cooler Master Silencio FP Series Case Fans
Cooler Master announces the launch of the new Silencio FP 120 PWM case fan right here in Malaysia. Dubbed “The Silent Rush”, the Silencio FP 120 boasts on delivering quiet and durable cooling solution.
The Silencio FP 120 PWM is compliant with the IP6X rating, which makes it more resistant to dust. This in turn would increase its life expectancy of up to 160,000 hours. Cooler Master has also included a new patented Silent Driver IC which uses extremely low current to save power and at the same time, create less vibration for better noise reduction.
On top of that, there is also a Smart Fan Engine which enables for a lower starting voltage and gives protection against fan jam. Should there be any obstructions in the fan, the fan will auto-resume once the obstructions are cleared.
cooler-master-fan
In terms of technical specifications, it has a dimension of 120 x 120 x 25mm with a speed of 800 – 1400 RPM +/- 10%. The Silencio FP 120 PWM case fan utilises a loop dynamic bearing, sports a 4-pin connector, rated at 12 VDC, and weighs 158g. In the packaging, there are also four metal screws and four anti-vibration rubber screw included for installation.
The Silencio FP 120 PWM comes with a 5-year warranty and it is now available at retailers nationwide. The product will set users back RM59, which is already inclusive of 6% GST.
Filed Under cooler master
Updated 5:56 pm, Thu, 23 April 15
    Transportation
    Touch ‘n Go Launches Enhanced RFID Lane For Seamless Tolling
    High Court Awards Man Who Sued JPJ RM40,000 Over MADANI Number Plates
    LHDN Expands MyTax e-Assessment Appeal System
    Streaming
    Apple Music Subscription Prices Increased In Malaysia
    JPN Dispels Viral MyKad Address Enforcement Campaign Claims
