Brought to you by UGREEN
UGREEN Launches Three New MagFlow And Nexode Pro Charging Solutions For Apple Devices In Malaysia; Starts From RM189
The collection features a liquid-cooled magnetic power bank, a foldable magnetic wireless charger, and a 160W wall charger with a built-in cable.
by Evelyn Chu
September 30, 2026
UGREEN New MagFlow And Nexode Pro Charging
Image: UGREEN
615
UGREEN has announced that it will be launching three MagFlow and Nexode Pro charging accessories in Malaysia which would be smarter options for your Apple devices. According to the company, the three products will be available in the country from 30 September onwards.
For your reference, the three devices are the MagFlow Pro Magnetic Power Bank 10000mAh 25W, the MagFlow 2-in-1 Foldable Magnetic Wireless Charger 25W, and the Nexode Pro 160W Charger with Retractable Cable. As their names suggest, the first two devices can magnetically attach to devices that support Qi2 wireless charging. On the other hand, the wall charger has a massive display to keep track of charging information and three additional ports to charge multiple devices simultaneously.
Image: UGREEN
Going through them in order, the MagFlow Pro Magnetic Power Bank is UGREEN’s newest portable power supply, featuring a 10,000mAh cell that supports surprisingly fast 25W wireless charging. Its Qi2 25W magnetic charging brings an iPhone 18 Pro Max to around 40% in 30 minutes, while the 10,000mAh battery delivers up to 1.28 charges for the iPhone 18 Pro Max. While it might seem like your standard power bank, what sets it apart from the competition is that it is the first of its kind to come with a built-in liquid cooling system.
The company calls this system CryoPulse™, and it is designed to minimise heat buildup during charging. Once the device is connected, it activates a micro-pump that circulates the coolant and draws heat away. You can also see the liquid flowing inside through a window on the rear.
Image: UGREEN
Image: UGREEN
We all know that heat can cause throttling, which in turn can result in performance drops. As such, this little addition can help ensure that the device charges quickly without getting too hot to hold. On top of that, the MagFlow Pro Magnetic Power Bank can provide up to 45W charging via its built-in USB-C cable, while its 30W input allows it to top up in a relatively short amount of time. Users can see all the handy information, like the device’s charging power, battery level, and number of charging cycles, through a small screen on the side.
Image: UGREEN
Image: UGREEN
Meanwhile, if you’re looking for something to complement your personal workspace, UGREEN’s MagFlow 2-in-1 Foldable Magnetic Wireless Charger has you covered. As its name suggests, its charging pad is meant to charge two devices at once, but it is specifically designed with iPhones and AirPods in mind.
Though it is meant to sit on tabletops, UGREEN has given the device a foldable design, making it more compact and portable than other charging stations. Despite this added flexibility, it does not come at the cost of its charging capabilities, as the magnetic pad supports up to 25W Qi2 charging for iPhones. Meanwhile, the other base can charge AirPods cases at up to 5W. Another neat feature is that the device can also work as a stand to support the iPhone’s StandBy mode.
UGREEN Nexode Pro 160W Charger with Retractable Cable
Image: UGREEN
However, if you need to charge more than two devices at once, the UGREEN Nexode Pro 160W Charger with Retractable Cable is here to fill that gap. According to the company, the wall charger can power up to four devices simultaneously, thanks to its two USB-C ports, one USB-A port, and the built-in USB-C cable.
As for charging output, both the retractable USB-C cable and USB-C1 port support up to 140W, while USB-C2 can deliver up to 100W and the USB-A port up to 22.5W. The charger has a maximum combined output of 160W across all ports. UGREEN says the built-in cable measures 70cm and can be extended or retracted to the desired length, giving you some flexibility in managing the cable when charging multiple devices.
Image: UGREEN
Image: UGREEN
And, much like the power bank mentioned earlier, the Nexode Pro 160W Charger comes with a built-in screen that displays charging information. That said, users can also download the UgreenConnect app, which provides remote access to the charger so they can check its status. The app also lets them adjust charging modes and even change the display wallpaper.
Pricing And Availability
Image: UGREEN
As mentioned earlier, the UGREEN’s new MagFlow Pro Magnetic Power Bank, MagFlow 2-in-1 Foldable Magnetic Wireless Charger, and Nexode Pro 160W Charger with Retractable Cable will be available in Malaysia on 30 September. They are priced at RM479, RM189, and RM419, respectively.
Those interested can purchase the devices via the company’s Shopee, Lazada, and TikTok Shop pages. For more information, visit UGREEN Malaysia’s official website.
This article is brought to you by UGREEN.
Related Article UGREEN Officially Launches Honkai: Star Rail Collection With Limited Collectible Gift Box
Filed Under MagFlow 2-in-1magflow proNexode Pro 160W Charger with Retractable Cableugreen
Updated 3:32 pm, Wed, 7 October 26
SendShareShareShare246Tweet154
    Data Breaches
    AEON Credit Introduces FacePay Via AEON Wallet
    Hands On
    MacBook Pro PROLED XDR (14-Inch) Hands On: Added Touches
