The UGREEN MagFlow Pro Is The First Power Bank With Built-In Liquid Cooling
The charging accessory can supposedly keep temperatures 10°C lower than conventional power banks.
by Nurul Kamil
September 5, 2026
UGREEN MagFlow Pro
484
At IFA 2026, UGREEN announced some new additions to its lineup of charging accessories. The highlight of this lineup is the MagFlow Pro, which is a magnetic power bank with built-in liquid cooling. According to the brand, the device is the first of its kind in the world.
The MagFlow Pro features a window so users can see the cooling system, which the company calls CryoPulse. When a device is connected, a micro-pump actively circulates coolant, so heat is drawn away from key components. As anyone with a power bank already knows, high temperatures can trigger throttling, causing charging to slow down. So, to combat such issues, the company decided to introduce a cooling system. Apparently, the addition of liquid cooling allows for 44% less heat buildup, keeping peak temperatures 10°C lower than conventional power banks.
UGREEN MagFlow Pro
UGREEN MagFlow Pro
Looking beyond the new system, the charging accessory boasts a 10,000mAh battery and can deliver a combined power output of 45W. This is split between the built-in USB-C cable, which delivers 30W, and the 25W Qi2 wireless charging pad. UGREEN says that the power bank is capable of charging an iPhone 17 Pro Max to 50% in just 40 minutes via this charging pad. Additionally, there is a smart display on the bottom right of the device, allowing users to see charging information. The USB-C cable can also double as a strap.
The MagFlow Pro is available in the US with a US$150 (~RM606) price tag. Meanwhile, local availability is still up in the air at the moment.
@lowyatnet
Here’s a quick look at some of the devices showcased at IFA 2026. From camera drones and robots to new charging tech, there’s a lot on display this year. #IFA2026 #IFA2026Berlin #TechShowcase #TechInnovation
While UGREEN may be the first to introduce liquid cooling to its product, it is not the only company adding active cooling to power banks. Anker also recently did the same, albeit with a different solution. Its new range of charging accessories includes the MagGo Power Bank 2 Pro, which sports a built-in cooling fan.
Related Article UGREEN Launches Three New MagFlow And Nexode Pro Charging Solutions For Apple Devices In Malaysia; Starts From RM189
Filed Under ifa 2026magflow prougreen
Updated 4:55 pm, Tue, 8 September 26
SendShareShareShare194Tweet121
    Data Breaches
    Hands On
    MacBook Pro PROLED XDR (14-Inch) Hands On: Added Touches
    Social Media
    AEON Credit Introduces FacePay Via AEON Wallet
