Home Computing
macOS 26.2 Developer Beta Introduces Edge Light Feature For Brighter Video Calls
It turns your screen into a ring light.
by Nurul Kamil
November 13, 2025
Apple macOS 26.2 beta Edge Light
Image: Apple via MacRumors
41
Apple is rolling out its latest developer beta for macOS 26.2. This update introduces a new feature called Edge Light, which serves to improve the user experience during video calls. Essentially, it allows the display to function as a ring light.
For the most part, the new feature is pretty straightforward. The Edge Light creates a border of light around the edge of the screen, providing additional illumination while conferencing. The position of this band of light is determined by Apple’s Neural Engine, which detects the user’s face and adjusts the border placement accordingly.
(Image: Apple.)
Aside from that, the user can control the brightness and colour temperature via sliders. Moreover, the user can set Edge Light to turn on automatically. With this setting enabled, the feature will turn on when the Mac detects that the user is in a dark environment. MacRumors notes that only MacBooks from 2024 and later will have this setting, however.
Of course, Apple recognises that the user may still need to use their screen during a video call. As such, the band of light does not cover the top menu bar. Furthermore, the light will recede when the user moves their cursor over it, so the user can still use the Mac normally.
(Image: Apple.)
Developers can already try out this feature, as long as they have a MacBook running on Apple’s silicon. As for when the Edge Light will be available for the public, it will likely be around December.
(Source: MacRumors)
RELATED:  AI Head John Giannandrea To Exit Apple Amid Siri Hiccups
Filed Under ApplemacOS 26
Updated 12:30 pm, Thu, 13 November 25
https://lowy.at/9r4gc
SendShareShareShare16Tweet10
    Transportation
    Cyber Security
    Reviews
    Deals
    Steam Spring Sale 2026 Ongoing; Here Are Some Suggestions
