  • Wanista
Home Computing
12-inch MacBook Air with Retina Display Will Ship in Q2 2015
by Andrew Cheng
March 6, 2015
MacBook-Air-vs-MacBook-pro-Retina-2013-sunlight-640x436
A 12-inch variant of the MacBook Air has been rumoured for the longest of time, but a new report is indicating that it will start shipping as early as Q2 2015, which will be around April to June 2015. Aside from having a 12-inch screen, the new MacBook Air has a plethora of new tricks as well.
One of the most notable changes is the amount of ports available on the 12-inch MacBook Air, which will only be as little as two. Yes, only two ports will be on the new MacBook air, which is a reversible USB Type-C port and a headphone jack. This was done in order to make it as thin and light as possible.
12-inch-macbook-air-3
Ports aside, the new MacBook Air is also considerably smaller than the 13-inch model (obviously). Surprisingly, however, the 12-inch MacBook Air is also slightly narrower than even the smaller 11-inch model, although it will be a little bit taller to accommodate the bigger display size. Apparently, this was made possible by reducing the bezel of the 12-inch Air.
12-inch-macbook-air-1A rendering of the 12-inch MacBook Air (middle) compared to the 11-inch model (left) and 13-inch model (right)
Interestingly, this new MacBook Air will also be much thinner than any of its predecessors, including the smaller 11-inch model. This, however, comes at a price. The trackpad will no longer have a click to it, and there will be a limited amount of ports available as previously mentioned. If you want to learn more about this new Macbook Air, you can do so here.
12-inch-macbook-air-212-inch Air (left) compared to the 11-inch model (right)
The 12-inch Retina Display MacBook Air will start shipping in the second quarter of 2015. Hopefully, Apple will unveil this new product – or at the very least, tease it – at its upcoming event on the 9th of March 2015.
RELATED:  Apple Reportedly Hosting Its First Event Of The Year On 4 March
(The Wall Street Journal via The Verge, 9to5Mac)
Filed Under apple macbook airMacBookMacBook Air
Updated 6:16 pm, Fri, 6 March 15
http://lowy.at/P3EHn
Share2Tweet1SendShare
    Banking
    E-commerce
    Android Phones
  • Wanista
