Home Mobile Phones
iPhone Air Is The Comeback From The 2014 iPhone 6 Bendgate
The iPhone 17 Pro models, on the other hand, may have started a new "-gate" controversy.
iPhone Air w box JerryRigEverything
Image: JerryRigEverything / YouTube
42
Anyone remembers the whole bendgate controversy back in 2014 with the iPhone 6? It’s been over a decade since, with the launch of the iPhone 17 series now behind us. Launching alongside the trio is the iPhone Air, the thinnest phone made by the bitten fruit brand Apple. And it may just be the ultimate response to the bendgate controversy.
Serial torture tester Zack Nelson, via his YouTube channel JerryRigEverything, has put the iPhones to his usual series of abuse. What the iPhone Air and 17 Pro share in common are the new Ceramic Shield 2 glass. This means they only start showing marks when scratched with a pick that’s is level 8 on the Mohs scale of hardness.
iPhone 17 Pro paint chipping
iPhone 17 Pro paint chipping zoom
There’s the usual scratch test that damages the phones’ titanium and aluminium sides just the same, but this also extends to the back of the iPhone 17 Pro’s new aluminium unibody back. Except, the sharp corners around the camera bump, or as Apple calls it, the plateau.
Because the edges here are relatively sharp. Because there isn’t enough surface area for the anodising process to completely take hold, the proverbial paint here is easily stripped away, be it by a coin or a key. This doesn’t happen anywhere else, where the apparent marks can be simply wiped off.
iPhone 17 Pro paint
So if you care about their cosmetic look, your iPhone 17 Pro or Pro Max should never share a pocket with anything else. That, or you need a case.
The bend tests though sees all three phones pass with flying colours. For the iPhone Air specifically, it flexes a little, but snaps back into shape once the force is relieved. But Zack has decided to go the extra mile with the the thinnest Apple phone made by Apple. Using a crane and a scale, he could apply amounts of force on the phone that human hands could not. And the phone only started cracking at 55kg of force, and snapping at 97kg.
RELATED:  The Next Apple Wearable May Be An AirTag-Like AI Pin
iPhone Air bend
If nothing else, this serves as a great endorsement for the iPhone Air. Maybe not so much for the iPhone 17 Pro and Pro Max. Probably fitting then that the Air model only has the bumper and clear cases and the 17 Pro gets the clear, silicon and TechWoven cases.
(Source: JerryRigEverything / YouTube [1], [2])
@lowyatnet
The iPhone 17 series and iPhone Air are officially available starting today. Those who have placed their pre-orders are at the Apple store at The Exchange TRX to collect their devices. #iPhone17 #iPhone17Pro #iPhoneAir #AppleMalaysia #iPhone17Series
Filed Under AppleiPhone 17 proiPhone Air
Updated 7:27 pm, Fri, 26 September 25
https://lowy.at/qccet
SendShareShareShare17Tweet11
    Reviews
    Mobile
